Author Topic: lambda oxygen sensor golf turbo  (Read 4926 times)
Offline dwood
« on: 23 June 2007, 18:49 »
hi i need some help
after running my vag-com today after very poor idle ive came up with the fault
 oxygen (lambda) sensor malfuntion in circuit   fault code 16514
 mixture adaptation  adaptation limit (add) exceeded fault code 00561
can you let me know if the adaptation mxture limit is becuase of the lambda sensor failing or is it somthing else
also is it very hard to fit new lambda sensor thanks in advance :smiley:
« Last Edit: 23 June 2007, 19:33 by Rhyso »
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: lambda oxygen sensor golf turbo
« Reply #1 on: 23 June 2007, 20:45 »
Only ever removed & replaced one when I decatted my old French tin can - 306!  The fooker had welded itself to the cat - Had to heat it up & get the cat in a vice to remove!!   :angry:   :grin:
IIRC, new ones from Pug cost other peeps roughly £100.  Have never enquired about a Mk4 one, sorry.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
« Reply #2 on: 19 August 2009, 15:46 »
hi i need some help
How uncanny!!! :o  Just done a search on one of my engine codes & this thread came up!  :D
These are 2 out of the 3 codes that I've got at the moment!  :(
Plus, also got a nasty rattle from the manifold/downpipe area.  :cry:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 19 August 2009, 17:38 »
budget around £80 for it. Get a gen Bosch item too
« Reply #4 on: 19 August 2009, 19:27 »
Definitely a lambda sensor, then?  It's just that I've got a rather unnerving rattle (esp. under load) coming from the manifold area.  :(
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 19 August 2009, 19:37 »
heatshield?
« Reply #6 on: 19 August 2009, 19:43 »
heatshield?
Hope so!  :D
Can't jack it up ATM as the shed keys are at the future mother-in-laws' thanks to the missus!  :D
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 19 August 2009, 22:05 »
you still got a cat?
« Reply #8 on: 19 August 2009, 22:34 »
Yes - Anon. S/H sports cat.  That was my first thought followed by Manifold, TBH.  :lipsrsealed:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 19 August 2009, 22:42 »
time for a decat then :wink:
