Author Topic: hi, need some advice on starter motor  (Read 1819 times)
Offline BobbyT
« on: 23 June 2007, 17:27 »
hi all, having a little trouble with starting the car, i fitted a second hand starter the other day and it worked fine at first but now seems to be doing what the last one did - turn the key and its quite slow to turn the engine - sometime it kicks in and sometime it doesnt! now i dont think its the starter which is at fault - but what else could it be - i am missing one of the mounting bolts for the starter which i suppose could be the problem. Also there are two wires that go to the motor on spade connectors - red and black - now can someone tell me the correct place for each wire as at the mo i have red to the connector nearest the engine and black to to the lower connector - is this correct? cheers, rob
Offline [han]
  • Graphic Designer for Haribo
Re: hi, need some advice on starter motor
« Reply #1 on: 24 June 2007, 00:12 »
i can't helop i'm afraid, but i hope you get your car sorted... i feel for people in my situation!!!!
Offline BobbyT
« Reply #2 on: 24 June 2007, 19:11 »
all sorted now!  :smiley:
Offline [han]
« Reply #3 on: 26 June 2007, 13:26 »
what was it
Offline BobbyT
« Reply #4 on: 27 June 2007, 09:11 »
well, i replaced the bat just to be sure and fitted a second bolt to it from b & q, if the motor was loose i guess it wouldnt engage the way it should!  :smiley:
up your neck of the woods for six weeks han! off to leconfield to do me hgv course! get to live at home (hornsea!! yay!! lol) lets hope i dont get washed away! hows the river through york?
Offline [han]
« Reply #5 on: 27 June 2007, 12:50 »
rivers ok, but my village is a little bit wet!
when you comin up? theres a meet in hull on the 15th july???
Offline BobbyT
« Reply #6 on: 27 June 2007, 14:44 »
cool! start the course this monday! so should be about! where abouts in ull is it?  :undecided:
