Author Topic: new head? 8v...  (Read 749 times)
Offline dabill
new head? 8v...
« on: 23 June 2007, 17:19 »
hi all, been messing around with ideas in my head, an i believe my cars bottom end may be from an audi 80... now i believe that the bottom end is a 5 cylinder and so would accept the 5 cyclinder head from the audi 80, but is this head any better than the one thats in a golf gti? and would it be worth finding one and having it skimmed polished etc... or could i get the same gains from my 4 cyclinder pb head?
also toying with the idea of a porsche turbo engine, think its 928's or something like that with a turbo? any ideas? i.e. can it be done?
cheers, rob
noble tuned - and still not fast enough!
Offline gteyes
Re: new head? 8v...
« Reply #1 on: 23 June 2007, 17:29 »
m8
if you have a 5cyl bottom end you have to have the same as a head  as in inlets and exhaust valves for each cylinder your car would not run and would look totaly out of place if you had 5cyl bottom end and 4cyl head :laugh: :laugh:
5cyl there will be 5 spark plugs one for each cylinder
4cyl will have four plugs
Offline dabill
Re: new head? 8v...
« Reply #2 on: 23 June 2007, 17:33 »
hummm... wonder if you noticed i know fubar all about engines... anyhoo... is the audi head any better than the golf one cos i know the b/e is definetly off the audi  :grin:
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: new head? 8v...
« Reply #3 on: 23 June 2007, 17:48 »
How do you know the bottom end is off an audi?
if it is it may be a 2litre 8v or 16v, depending on your car. if its a 16v the engine code will be 6a and if its a 2.0 8v then the engine code will be 2e (i think?).
Offline dabill
Re: new head? 8v...
« Reply #4 on: 23 June 2007, 18:08 »
its an 8v, and im pretty sure cos the guy who sold it me said it was... plus i tried the mk3 oil pump and it was wrong, and the audi one accepts the standard golf gti pump...unless im wrong again haha...
rob
Offline mookie
  • Geordie ABF!
Re: new head? 8v...
« Reply #5 on: 24 June 2007, 20:33 »
The standard 8v head will go straight on the Audi 80 block with an engine code of 3A, for an 8v 2litre setup. Sound like this is what you have.
