Author Topic: Getting laquered  (Read 596 times)
Offline dadrathers
Getting laquered
« on: 22 June 2007, 22:18 »
I need to do a paint job on my front (plastic) bumper which is in Brilliant Black Metallic.
I have never sprayed using metallic before so,
1. How much laquer do I need compared with the metallic paint?
2. Should I get the laquer from VW - I have no choice with the paint?
3. Any tips for doing a top job - I am OK with preparation and undercoat etc?
Cheers.
sharpie
Re: Getting laquered
« Reply #1 on: 22 June 2007, 22:32 »
if you get vw paint they come in packs with the lacquer... doesnae matter much about the lacquer tho, but go with genuine vag paint to get a better colour match.
prep is everything, get a really good smooth surface before you start, few coats of paint and a few more lacquer on top once it's done to protect it. you'll need a fair few cans cos the vag ones are tiiiiny!
edit - 2 coats of primer too before you start! you can flat it off with some 1500 paper between coats if you want a smoother finish
