Author Topic: immortal - mk4 1.8t upgrades  (Read 92332 times)
Offline Immortal
  • 1.8 Turbo GTI (AUM)
Re: immortal - mk4 1.8t upgrades
« Reply #10 on: 12 August 2007, 16:46 »
Forge 007p Dump Valve
Tools Required
1, Flat head Screwdriver
Step One: Release the three quarter turn screws & remove the plastic engine cover.
Step Two: Remove the three jubilee clips holding the OEM dump valve to the hoses.
Step Three: Replace the jubilee clips & fit the forge valve, The hoses need to be tight but dont go nuts & have the clips cutting into them.
Step Four: Replace the plastic engine cover
Job Done!
Offline Immortal
« Reply #11 on: 21 September 2007, 00:08 »
I've not really done much recently. Just replaced a split hose & fitted some new plugs.
Hope to do some more mods next month :cool:
Offline Immortal
« Reply #12 on: 05 November 2007, 18:44 »
Just ordered myself some bora vents :cool:
Offline Ashmond
  • Money, b!tches And Boost
« Reply #13 on: 10 November 2007, 18:02 »
where did you order the bora vents from mate?
Offline Immortal
« Reply #14 on: 10 November 2007, 18:57 »
Offline Ashmond
« Reply #15 on: 10 November 2007, 21:33 »
cheers!
Offline Immortal
« Reply #16 on: 13 November 2007, 20:12 »
No probs mate. I was feeling flush earlier so I've also ordered the R32 door handles & console trim
Offline Immortal
« Reply #17 on: 16 November 2007, 10:31 »
Finger Plate & Door Handles
Tools Required
2, No.1 Point Pozidrive Screwdriver
Step One: Pull off the inner grip from the fingerplate
Step Two: Pull fingerplate upwards to remove. Disconnect wire
Step Three: Remove switch assembly (three screws)
Step Four: Reassemble in reverse order.
Step Five: Prise door handle off using flat screwdriver. I found it easiest to prise from the bottom of the handle.
Step Six: Push new handle into place. Job done
Offline Immortal
« Reply #18 on: 17 November 2007, 11:02 »
Bora Vents Loom
As most of you will probably know, the wiring loom for the Bora vents is almost impossible to get now. So I've made my own! All credit goes to old_n07 on ukmkivs for his how to guide
« Last Edit: 19 November 2007, 00:34 by immortal »
Offline Immortal
« Reply #19 on: 19 November 2007, 00:37 »
Console Trim
Before:
After:
