Author Topic: Electric window  (Read 597 times)
Offline Moonwalker
Electric window
« on: 22 June 2007, 18:15 »
Like a dopey sod, I ocked my keys in the car and so had to break a window to retrieve them. now, I've got a window I need to fit, but the electric window doesn't work. I checked the wires going into the motor and there's power going to them. Is there anything I can do to the electric window motor to make it work?
Offline Classic16v
Re: Electric window
« Reply #1 on: 24 June 2007, 15:27 »
Don't know if this will be the problem (seeing as it's after you broke your window that it doesn't work), but I had problems with my electric window and bought a new regulator - turns out the problem was the window switch in the centre console and my old motor and regulator worked fine!  The switch was just short circuiting - it went for no reason at all, so it could be nothing to do with you breaking in!
I took the mechanism out of the door and tested it on a battery so that might be worth a try to check and still goes up and down.
