Author Topic: Removing Sump Plug!  (Read 8931 times)
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
Re: Removing Sump Plug!
« Reply #20 on: 28 May 2006, 00:27 »
Can't say I've ever tried to set light to oil but the blow torch I'm thinking of is capable of something like 3200 deg C - would that be hot enough  :smiley:
As for the driver, use a bigger hammer  :wink:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline gtibob
« Reply #21 on: 28 May 2006, 11:21 »
This is a common problem on the 16v. If you hav'nt messed it up too much an impact socket will still fit because of the 6 sided design, it dos'nt need the points like a normal socket. Never failed to remove one of these with an air gun. Front hub nuts come off like this too and they are usually in excess of 200ft/lbs.
« Reply #22 on: 31 May 2006, 12:39 »
 :undecided: Reading that last reply I'm wondering if you think i'm talking about using an air gun  -  I mean one off these bad boys  :smiley:
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101080&ts=75409&id=16735
I couldn't maintain my 25 year old car without one  :grin:
my dub project:-
Offline gtibob
« Reply #23 on: 31 May 2006, 12:48 »
I would'nt chance using a hammer operated impact driver, I think you might risk cracking the sump.  :cry:
« Reply #24 on: 31 May 2006, 12:52 »
If the sump plug is already stuck I think thats a risk worth taking - the other option is a new sump anyway  :laugh:
my dub project:-
Offline gtibob
« Reply #25 on: 31 May 2006, 14:09 »
Better to just drop the sump than risk breaking it, this has to be an expensive item and a cast alloy sump is probably VAG only :sad:
« Reply #26 on: 31 May 2006, 14:52 »
 :undecided: sumps are about £20 (I bought one after a "speed-hump" incident) & nobody said anything about cast sumps, but yeah they would cost some.   :nerd: Never hit cast alloy - it'll break for sure
my dub project:-
Offline gtibob
« Reply #27 on: 31 May 2006, 15:50 »
I assume we are talking about an ABF engine here. It should have a cast sump. The plugs are notoriously hard to remove because of the large thread area probably designed to prevent ham fisted numpties stripping them out as they would on the normal sized steel sump plug, good luck!
« Reply #28 on: 31 May 2006, 16:08 »
 :embarassed: I don't know much about mk3's as I cant stand them  :grin:
so they've got a cast sump have they  :shocked: oooh I wonder if it'll fit the older engines  :undecided: anyone???
my dub project:-
« Reply #29 on: 31 May 2006, 16:12 »
yes it will, as does the MK3 rubber sump gasket!  Though you need to replace the bolts too.  Some seem to have star bit bolts in rather than normal hex ones too, which would make removing/refitting a bit easier in the tight spots  :cool:
