Author Topic: Removing Sump Plug!  (Read 8933 times)
Offline GLC GTI
Re: Removing Sump Plug!
« Reply #10 on: 25 May 2006, 15:59 »
Got all these problems with my 16 valver at the mo :sad: gonna get my mechanic to do it as the b!tch is stuck tight!
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #11 on: 25 May 2006, 16:08 »
Can't you get an impact driver on it  :huh:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline monkeyalan
« Reply #12 on: 25 May 2006, 16:59 »
or a blowtorch to warm it up a bit?
« Reply #13 on: 25 May 2006, 17:07 »
 :grin: That could end in tears if the oil catches light
my dub project:-
Offline GLC GTI
« Reply #14 on: 26 May 2006, 13:36 »
As I said its gonna go inthe garage next week to be done MOT is due the week after so I'll just get it all sorted at once.
Ordered a sump plug from T'bay and it looks awfully small I reckon there has been a funk up cant be arsed to send it back only cost £3 and was from Hong kong so...
Best bet a stealership foe one then? Only problem is the nearest is about 40/50 miles ha, county life.
« Reply #15 on: 26 May 2006, 22:12 »
could always just take the sump off in the worst case, if you go that route drill a hole into the bottom of the sump to drain the oil out.  Obviously make sure you can get to all the sump bolts, and they all actually undo before you do that though  :grin:
Offline AudiA8Quattro
« Reply #16 on: 26 May 2006, 23:52 »
An impact driver won't shift an overtightened bolt.
Out of interest why would the oil catch light??
Offline mk316valver
« Reply #17 on: 27 May 2006, 01:08 »
I spent 2 hours the other day as-well, I ended up drilling a 6mm hole in the outer flange and using a punch and very large and persuasive hammer to loosen.
« Reply #18 on: 27 May 2006, 13:14 »
1.  :huh: what do you mean it wouldn't??? it works on ones that have rusted solid  :tongue:
2. Do you know what a blow torch is  :laugh:
my dub project:-
« Reply #19 on: 27 May 2006, 23:18 »
An impact driver won't get a bolt out that is done up to 30 lb ft+
In answer to your other question, yes i know what a blowtorch is  :laugh:
Now a question for you,
Do you know how easy it is to set light to engine oil?  :evil:
