Author Topic: Lhd Crystals  (Read 1782 times)
Offline OakeyDoak16v
Lhd Crystals
« on: 21 June 2007, 13:35 »
Does anybody know can lhd lights be adjusted to suit rhd cars?
Just bought a set off gay bay and seller is claiming complete ignorance to it.
Any thoughts greatfully appreciated
Offline tom26
  • team chumpy.
Re: Lhd Crystals
« Reply #1 on: 21 June 2007, 17:18 »
i have some too. There are 2 long screws at opposite corners which can be wound in/out to correct the alignment/direction :smiley:
Re: Lhd Crystals
« Reply #2 on: 21 June 2007, 21:11 »
Cheers tom, do you know if they will pass an MOT
Offline Egbutt Wash
Re: Lhd Crystals
« Reply #3 on: 08 November 2009, 15:32 »
No
Currently digging a bunker.
Dinky
Re: Lhd Crystals
« Reply #4 on: 08 November 2009, 15:34 »
http://www.motuk.co.uk/manual_120.htm
http://www.motuk.co.uk/manual_160.htm
^gives you low down on what is required for the mot with reference to headlamps :smiley:
Dinx :kiss:
Offline weazgti
Re: Lhd Crystals
« Reply #5 on: 08 November 2009, 22:20 »
http://www.goingfast.info/04_05/ebay_sales/pics/Headlights_LHD_to_RHD.html
You need to swap the adjusters round by pulling the light off.
This is what an ebay seller sent me. You will find out you have to do this because you will run out of adjustment.
Also when you ve swapped them youll need to drill a hole in the metal behind the light. Youll see when you go to refit them.
Ididnt get the lights in the picture by the way,they look tat. :grin:
No they wont pass the mot,i had to bang the standard ones in till i got the pics on how to do it.
Hope this helps.
« Last Edit: 08 November 2009, 22:29 by weazgti »
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Lhd Crystals
« Reply #6 on: 08 November 2009, 23:06 »
I have the same problem as I have to convert mine for UK registration. The mounting plates are also handed, so not sure if the lamps can be adjusted sufficiently. I was going to put mine back to normal spec. :undecided:
Offline Mew
Re: Lhd Crystals
« Reply #7 on: 08 November 2009, 23:12 »
Alternatively, buy me some new Hella lamps and you can have my rhd crystal lamps :wink:
Re: Lhd Crystals
« Reply #8 on: 09 November 2009, 00:22 »
Blimey, a 2 year old thread has re surfaced. :smiley:
Offline Sam
  • Sam I am
Re: Lhd Crystals
« Reply #9 on: 09 November 2009, 00:26 »
Can you trace its re-emergance back to anyone? Who is this guy anyways??
