Author Topic: rain sensors?  (Read 3452 times)
Offline Rog
  • Mk5 R32,5dr,Deep Blue,DSG,Sat Nav,Leather etc
Re: rain sensors?
« Reply #10 on: 21 June 2007, 09:01 »
I hate the auto wipe function as like some of you have found out it never get's it right. In this case man knows better than machine, I know when I need the windscreen wiped eg when it effects the visibility through the windscreen and also that there's enough water on it so that it doesn't wear the wipers out and scratch the glass!
I must see if I can cancel it through the computer menu or if not when it's first service is due. :undecided:
Offline TheReflex
Re: rain sensors?
« Reply #11 on: 21 June 2007, 11:09 »
Agreed.  Mine seems to go mental in light rain.  At this rate I'll be going through a new set of wipers every 6 months.
2007 GTI with a hint of Bluefin.
Offline Simonet
  • Pearl Black GTI ED30
Re: rain sensors?
« Reply #12 on: 21 June 2007, 11:14 »
I've had no problems, it works fine. Why use the Vag com to turn it off??? just move the stalk down and notch and it's turned off anway? Also, if you put it ino auto but use the intermitent wipe doo dah on the top, it stops the auto anyway. My only negative is if you get in the car after its rained (and you've cleaned your car so the water sits nicely) The auto sensor doesn't seem to detect any rain. However a quick flick of the wipers and back to auto and all is well
Offline wantmygti
Re: rain sensors?
« Reply #13 on: 21 June 2007, 12:10 »
I think that the 'doo dah' you refer to is the sensitivity adjustment. it does not or should not disable the rain sensor.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline SteveS
  • GTI ED30
Re: rain sensors?
« Reply #14 on: 21 June 2007, 14:55 »
as simple as this is its complicated. think ill need to see what i get when the car arives!
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline p3eps
Re: rain sensors?
« Reply #15 on: 21 June 2007, 18:26 »
I had my car for 1 day of rain before it went back to get fixed, and I have to say the auto rain sensor pi55ed me off thoroughly!!
Its way too sensitive, and even when I adjusted the 'dial' to minimum, the wipers were still going almost full pelt in light drizzle.
I'm the type of person who only wipes my window when I really cant see - I dont mind a few spots of rain on it.
My auto wipers just wanted to go non stop!  I do hope theres a way of disabling it.  I might phone and ask tomorrow morning, since the car is there just now!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
