Author Topic: Kenwood headunit has power but wont turn on  (Read 5815 times)
Offline Neaty
Re: Kenwood headunit has power but wont turn on
« Reply #10 on: 25 June 2007, 13:17 »
it wont work at all now, i reset it by pressing the button, input the security code then as soon as it either tries to play a cd or connect to a radio station it crashes again.
I try this again and again and it just crashes! pile of sh!te!
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #11 on: 25 June 2007, 13:29 »
If it won't work at all, you'll need to disconnect the permanent live for at least half an hour to let it clear itself down - just pull the fuse, there's no need to remove the stereo.
I moved from Pioneer to Kenwoods about 8 years ago when my friend was a sales manager there, and hence I got an awesome discount (and I got top notch tech advice).
Now he is no longer there, I once again have a Pioneer in my gap in the dash - I just couldn't be doing with the down time (and then the time spent re-entering all of my settings etc).
The greatest leveller of them all - the Carousel
Offline Neaty
« Reply #12 on: 25 June 2007, 15:00 »
ok so just pull the fuse out for half an hour or so then reset it and put my security code in?
thanks for your help mate
i defo wont be buying another kenwood thats for sure!!
Offline S11EPS
« Reply #13 on: 25 June 2007, 15:25 »
yeah, half an hour with no power to it should be sufficient for it to get a hold of itself.
I would avoid playing the discs you have identified as problematic, just for your own sanity...
Offline Neaty
« Reply #14 on: 25 June 2007, 15:30 »
ok cheers matey  :smiley:
well it appeared to be just one cd that was playing up, namely Van Halen Best of Both worlds, disc 1...now it is every cd i put in.
Offline mk2_singh
« Reply #15 on: 26 June 2007, 14:29 »
 :grin:
feel sorry for you mate but i know how you feel  :tongue:
Offline Neaty
« Reply #16 on: 26 June 2007, 14:38 »
ha ha cheers!
well its working now....touch wood. took the fuse out as per Sheps' advice and it now works....until the next time it crashes anyway!!
