Author Topic: HARNESS LAP MOUNTING POINT ON TUNNEL SIDE  (Read 646 times)
Offline lewis1641
  • stuck in the 90's
« on: 18 June 2007, 18:00 »
hi sorry if this has been covered but i cant find it.
i have an 87 8valve which is road legal but used for track days.  presently the standard front seats are being used with willans harnesses without problems.  i have just picked up a pair of corbeau forza buckets and plan to fit them very soon.  the problem is when i remove the standard seats i will lose the mounting point for the lap part of the harness on the tunnel side of the car. how do people get around this issue?  thanks in advance and i do apologise if this is the sort of issue people get bored of hearing about!!
Offline barkstar
Re: HARNESS LAP MOUNTING POINT ON TUNNEL SIDE
« Reply #1 on: 19 June 2007, 12:57 »
You can get mounting plates from Demon Tweeks with the correct thread for the eyebolt FIA approved type (the best) are about £2. These should be welded in.
Barkstar  :nerd:
Offline lewis1641
  • stuck in the 90's
« Reply #2 on: 19 June 2007, 13:36 »
fantastic i'll get some. thanks
