Author Topic: Removing Front wing Mk2  (Read 6324 times)
Offline phil88
« on: 17 June 2007, 19:13 »
whats the best way to remove the underseal that holds the wing to the car. have had a go before but failed. is there three bolts in the underdeal too? cheers, Phil
Offline Mark_H
Re: Removing Front wing Mk2
« Reply #1 on: 17 June 2007, 19:17 »
Hi,
I removed mine from my Mk2 90 spec and it was OK. There are two bolts under the underseal.
I used a longish lever bar to remove mine. !!!!!! I've heard heating the undersealer up helps
Mark
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #2 on: 17 June 2007, 21:11 »
bolts along the top, bolts below at the rear by the door, bolts below at the front end, bolt behind the grille bolt behind the bumper on the side, then you can open it up, chew out the sealer and undo the 2 in there.. simple  :cool:
btw mark cheers again for the wing, you had a look in my project?  :wink:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline nealey
« Reply #3 on: 17 June 2007, 21:25 »
I normally heat the wax up with a hot air gun or just set fire to it then get the screwdriver on it untill i find the bolt, the nsf wing always seems to be the most stubborn as well
Offline phil88
« Reply #4 on: 18 June 2007, 22:48 »
cheers all for your help, took them off today. check my project page  :grin:
