Author Topic: tyre warning light!  (Read 1885 times)
GreyTornado
tyre warning light!
« on: 17 June 2007, 13:55 »
driving at a normal speed yesterday when this symbol suddenly lit up... so i pulled over and checked my tyres... all ok nice and firm... so carried on driving. got to petrol station and did a check... again all ok.....can't get to see a machanic till tommorrow but this is now really bugging me and i'm imagining all sorts going on.   can anyone help me out and give an idea why this has come on
thanx
Offline teebee
Re: tyre warning light!
« Reply #1 on: 17 June 2007, 13:59 »
Just hold the 'flat tyre' button down for 2 or 3 secs to reset, then see what happens.
Offline GTI CV7
« Reply #2 on: 17 June 2007, 16:04 »
This light appeared on my car about a week ago... I checked the pressures when I got home. They were all within 1-2 psi except one of the back tyres which was about 3psi down. I topped them up, reset it and it's not been on since. My front tyres are down to about 3mm of tread... Am I right in thinking that the computer uses data from the ABS sensors to detect differences in wheel diameter? I've read somewhere that this data is also used by the sat nav to calculate position when the satellite signal is lost momentarily. (Dead reckoning)
Red GTD 5dr, Leather, 18", RNS510, Dynaudio, Bluetooth and Park Assist
GreyTornado
« Reply #3 on: 18 June 2007, 07:43 »
cheers Teebee... i did as you recommended... and its gone off!! sometimes when i drive this car its like being in a cockpit of a plane!!  :embarassed:...
Phil mcavity
« Reply #4 on: 18 June 2007, 08:50 »
mine came on 10 days ago, me thinks its to do with ambient air temperature, getting hotter and warmer outside, so tyre pressures will alter slightly, mine was 3 psi lower on all wheels, up't it back to 36psi, reset button on consol and alls well  :wink:
Offline Simonet
  • Pearl Black GTI ED30
« Reply #5 on: 18 June 2007, 09:46 »
being lazy..... is it 36psi all round for the 18"
Offline Teutonic_Tamer
« Reply #6 on: 24 August 2007, 17:44 »
Yes.  On the Golf, the TPMS doesn't measure the actual pressure, but merely looks for differences in rotational speeds.  It uses some kind of fuzzy logic to allow for gradual tyre wear, so, if you have brand new boots on the rear with 7½mm tread, and the fronts are on the TWI at 1.6mm - it will still work.  However, if you were then to swap those wheels front to rear, then it would ping the TPMS warning.
One downside of this system (compared to actuall pressure sensors, like in my RS4), is that it can take 20 minutes to register a puncture - pretty pants if you ask me!
Yup.  All factory fitted SatNav systems use this data, unlike all dash mounted stand-alone, and many aftermarket replacement head units.  It works very well too.  On my "european tour" in my RS4 last May, I went through a long tunnel (near a resevoir in Switzerland, going towards Austria) - seemed like 15minutes underground - and the SatNav screen displayed exactly where I was on the map!
I feel like a homo
