Author Topic: MK2 Roof lining  (Read 3041 times)
Offline Retrocool
MK2 Roof lining
« on: 17 June 2007, 12:02 »
Hi all,
Another week, another problem, driving along at 60mph with the back window open, look in the rear view mirror to find the headlining has come unstuck and half come away from the roof!! :angry:
Apart from being an eyesore, I can't see out of my back window.
How would should i go about sticking this back on?? Are any glues that are better for this than others, are there any i should avoid??
Thanks
« Last Edit: 17 June 2007, 12:32 by Retrocool »
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: MK2 Roof lining
« Reply #1 on: 17 June 2007, 13:01 »
have you lost the plastic trim piece goes between the c pillars across the back, that holds it up?  :undecided:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline cняis
Re: MK2 Roof lining
« Reply #2 on: 17 June 2007, 21:49 »
DO NOT use contact adhesive like evo-stick because it will start to melt/warp the lining. mine looks like theres been a fire in the back  :huh:
i'd use good spray glue, like the stuff they use to fix carpets down with.
Offline Fez
Re: MK2 Roof lining
« Reply #3 on: 19 June 2007, 20:58 »
i have the same problem. I use spray glue, but find that it only lasts for a few weekes the i have to re apply it  :sad:
Offline Retrocool
Re: MK2 Roof lining
« Reply #4 on: 19 June 2007, 21:35 »
well I used spraymount as a very temporary fix to start with, and it held it for about 12hrs! :grin: i did say temporary!!
it fallen back down again now and annoying the crap outta me so gotta get it sorted.
Fez did you use carpet glue like suggested above??
Offline Fez
Re: MK2 Roof lining
« Reply #5 on: 19 June 2007, 21:57 »
no but will be on the case this weekend ;)
wheres the best place to get some from? any carpet place?
Offline Retrocool
Re: MK2 Roof lining
« Reply #6 on: 20 June 2007, 07:19 »
that or ebay..?
Offline cняis
Re: MK2 Roof lining
« Reply #7 on: 20 June 2007, 12:31 »
just do NOT use contact adhesive as the solvents will starts to melt the lining... mine has shrunk and rippled and looks gash!
carpet spray glue would be a good choice  :cool:
Offline BIG E
Re: MK2 Roof lining
« Reply #8 on: 20 June 2007, 19:11 »
Retrocool!!!!
Mate, I just read you message. I don't know if you have done the deed yet with you roof BUT... I had the same problem and I just used some 'cough!!!' wall paper paste. Am still unsure of the results yet??
Please let me know how you get on with what ever it was you were using.
Offline Retrocool
Re: MK2 Roof lining
« Reply #9 on: 20 June 2007, 20:14 »
I haven't had a chance to get at it yet! rest assured I will this weekend-down the bristols carpet warehouse i reckon, to get i some carpet glue... i'll let you know the results...
