Author Topic: Speedo stopped working  (Read 954 times)
Offline l1ncs
« on: 16 June 2007, 21:12 »
Was driving along today and just noticed that the speedo has stopped working. The rev counter still works fine. Also the digital speedo just reads about 4 mph all the time. The car is a 1990 8v gti. The car has just had a head gasket amongst other things. It worked fine after picking it up but later on the same day it stopped working. Does anyone have any suggestions of the possible problem and a remedy?
Offline l1ncs
Re: Speedo stopped working
« Reply #1 on: 17 June 2007, 17:19 »
I had a look under the bonnet today and found this wire had come loose. Could this be causing the problem? If not, does anyone know what these wires are for?
Offline Mr Blue
« Reply #2 on: 17 June 2007, 21:44 »
Check the back of the clocks as the speedo cable might have come loose.
If thats ok then its your speedo cog on the gearbox.
Fix that broken wire anway.
Offline Philpy
« Reply #3 on: 17 June 2007, 21:48 »
sounds like the cable has snapped..... Not a massive job!
« Reply #4 on: 18 June 2007, 10:27 »
that wire has got nowt to do with the speedo, its the throttle switch wire.  That means your car wont idle properly, and you wont get fuel enrichment when you floor it either!
Offline l1ncs
« Reply #5 on: 18 June 2007, 18:13 »
Quote
Nice one, that might explain why the car wasnt pulling quite as well as I was expecting. Cheers for that.
Offline l1ncs
« Reply #6 on: 12 July 2007, 22:10 »
When you say the cable may have snapped, how and where do I go about checking? If i take the clocks out and check around the back will it be obvious then?
Also when you mention it could also be the speedo cog on the gearbox, is this a big/costly job to fix?
Offline Agreeable Slick
  • Unit
« Reply #7 on: 12 July 2007, 22:21 »
