Author Topic: Gti 8v G Reg Mk2  (Read 1934 times)
Offline KelsoGti
Gti 8v G Reg Mk2
« on: 15 June 2007, 13:48 »
I have yet got this car started im just wondering if i can find out if its got PAS. the owner broke the alarm fob some im just tracing wires back to remove immob and alarm. what does the PAS pump look like and where is it on these. or easy question did the 1989 model come with PAS or not?
cheers kelso
Offline Simon8v91
Re: Gti 8v G Reg Mk2
« Reply #1 on: 15 June 2007, 14:01 »
dont think PAS was standard.  Look for the fluid reservoir with red cap.  The PAS pump is belt driven next to your water pump (near bottom of cam belt cover) drivers side.
If it has not got PAS steering will be heavy when parking.   :smiley:
Offline KelsoGti
« Reply #2 on: 15 June 2007, 14:03 »
i'll take a look tonight thanks for the advice.
What kind of job is it to convert to PAS? and how much for parts just roughly :)
thanks again!
Offline Simon8v91
« Reply #3 on: 15 June 2007, 14:15 »
converted a 1.8 driver to PAS about 5 years ago.  Collected the bits from scappers over a period of months.  You will need, pump, pulleys, rack, reservoir,hoses and the odd bracket (we bought an exchange rack from GSF).  Used my GTI with PAS as a guide - very useful.
For price have a look on ebay / GSF. But we spent about £100
Took a very long saturday to do the job  :laugh:
Offline KelsoGti
« Reply #4 on: 15 June 2007, 16:56 »
thank you for the list of parts mate much appreciated! :D
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #5 on: 15 June 2007, 17:56 »
Mew and I have pretty much everything required to convert a car to powersteering for sale if your interested? :)
« Reply #6 on: 18 June 2007, 10:57 »
pas was never standard unfortunatly!
you need:
Rack & track rod ends
Pipes
Reservoir & bracket
Pump & brackets
Outer crank pulley
Rack->column universal joint
UJ boot
Bracket from the front of the block to hold the pipes up
Bracket from passenger side chassis leg to hold pipes and prevent them rubbing on the brake line
Fill the system with 2l of Dexron II ATF, to bleed leave the cap off & turn the rack from lock to lock a few times keeping the level topped up.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #7 on: 18 June 2007, 12:35 »
Sorry to hijack the thread. :tongue:
Rubjonny, I've just P.Med you.
Offline robiwill
« Reply #8 on: 18 June 2007, 16:55 »
PAS only became standard on the MK2 Gti in 1991 was standard from 1990 on the 16V however do not us the pas pump mounting bracket for a 16v on an 8v it will not fit everything else though is the same.
be care ful with people selling the kits on ebay that they are complete and have the correct bracket for an 8v usually the parts missed out are the powersteering fluid tank bracket and the steering column UJ joint which is different also to the standard one and bolts.
one of our most coman questions is I bought a kit off ebay and need.....
Would help you out if we had one in stock but only got 16V set ups at present
Offline KelsoGti
« Reply #9 on: 19 June 2007, 16:18 »
thanks guys most appreciated! I have just bought a full setup off a golf breaker for £55 is that cheap or expensive?
its the 16v one but will fit right? appart from some brackets?
