Author Topic: Corroded rear beam help  (Read 1272 times)
Offline cняis
« on: 13 June 2007, 21:36 »
How problematic is the following:
"Rear axle corroded around front mount bushes"
Im guessing this is where the beam mounts to the car? Is this a common problem and how can i overcome it besides buying a new rear beam £Â£Ã‚£
 :undecided:
sharpie
Re: Corroded rear beam help
« Reply #1 on: 13 June 2007, 22:14 »
mot fail or advisory? no ask the garage?
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #2 on: 13 June 2007, 22:35 »
Beam from a scrap? not expensive afaik?  :undecided:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline cняis
« Reply #3 on: 13 June 2007, 23:14 »
i'd imagine it to be expensive to swap the parts over as im no mechanic.... anyway the last MOT advisory sheet (Nov 06, 8k miles ago) says the following:
  • Nearside rear radius arm rubber bush deteriorated but not resulting in excessive movement [2.4.G.3]
  • Offside rear radius arm rubber bush deteriorated but not resulting in excessive movement [2.4.G.3]
So one place says bushes, the other suggest a corroded beam...?
« Reply #4 on: 13 June 2007, 23:34 »
beam from scrapy, poly or OE bushes your choice.. get em pressed in, you can do the swap yourself..
at leastim pretty sure you can, it all needs unbolting and dropping down like..
Quote
« Reply #5 on: 14 June 2007, 13:04 »
i think you need to get them to show you what the problem is, it might be rust on the actual boot floor?  Or they might be muppets and mean the rear wishbone bushes  :grin:
