Author Topic: golf 8v/16v springs  (Read 686 times)
Offline paultownsend
golf 8v/16v springs
« on: 13 June 2007, 17:40 »
hi all.  the ebay seller i got my gaz adjustable dampers gave me some new free apex 40mm lowering springs after a problem i was having with my eibach 8v springs not working. only thing is now, the front end sits higher, nearly an inch. i consider the springs now to be 'run in'. do you think this is because the 16v engine weighs more so the springs are harder to compensate? Paul
Offline Gambit
Re: golf 8v/16v springs
« Reply #1 on: 13 June 2007, 19:53 »
as standard 16v springs are generally a heavier poundage than 8v springs. but alot of aftermarket spring manufacturers dont adhere to this
if the springs are branded as a 16v only product then i would say they are a heavier poundage. but an inch height difference is a bit extreme!!
« Reply #2 on: 13 June 2007, 20:16 »
just checked the apex web site, and the springs are listed with different part numbers for the 8 and 16v's. the 16v springs also lower by a further 10mm
