Author Topic: Oil Leak  (Read 3429 times)
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
Oil Leak
« on: 13 February 2004, 00:49 »
I have an oil leak that's quite bad, should i try using one of these stop oil leak products that are on the market or not?
thx for your help
regards marc
golfvr6
Re:Oil Leak
« Reply #1 on: 13 February 2004, 00:53 »
Where is the oil leak, and how much oil is leaking out?
I wouldn't use one of those products, i would repair the leak.
turbo
Re:Oil Leak
« Reply #2 on: 13 February 2004, 01:03 »
hi there if you can get hold of valvoline maxlife oil this may do the trick and will certinetly help..
Offline marcogolfo
Re:Oil Leak
« Reply #3 on: 13 February 2004, 01:04 »
the oil leak appears to be coming from the dipstick area
Fielder5757
Re:Oil Leak
« Reply #4 on: 13 February 2004, 01:08 »
could be a gasket....Have you tried going to a garage and asking them just to look at it? if your leaking oil then your gonna have problems, Especially if your ragging your car. Oil works on pressure, so if your leaking oil then that means theres a lack in oil pressure and parts of your engine are being deprived of oil, This will in the long run damage your cars motor.
Offline marcogolfo
Re:Oil Leak
« Reply #5 on: 13 February 2004, 01:08 »
hey vwsystems do you work for valvoline or something.  Its just that every post seems to mention valvoline lol, just asking:)
I guess i need to get to a garage and have them take a look
Say for instance it is a gasket is it likely to burn a huge hole in my pocket?  What i'm saying is how much are they likely to do me for? thx
« Last Edit: 13 February 2004, 01:10 by marcogolfo »
Fielder5757
Re:Oil Leak
« Reply #6 on: 13 February 2004, 09:46 »
If its your rocker gasket your looking for ?3 for the gasket and ?20 labour if your too lazy to do it your self.
Offline mk1
Re:Oil Leak
« Reply #7 on: 13 February 2004, 19:28 »
What car and what engine?. May get more response in the garage forum ;).
Oil leaking from the dip stick area, hmmm maybe the plastic adapter is broken or the engine breather is blocked. It would take a massive oil leak on the pressure side to lower oil pressure to a level that could cause engine damage, more likely to damage engine due to a lack of oil.
Offline modulater
Re:Oil Leak
« Reply #8 on: 13 February 2004, 20:16 »
You need to clean the engine so you can see where the fresh oil is leaking from, ideally steam cleaning it would be the best option but you can do it with something like jizer and a decent hose.
I had a leak on the front and replaced the dipstick tube but it still leaked, mine turned out to be the oil pressure sender leaking.
turbo
Re:Oil Leak
« Reply #9 on: 14 February 2004, 01:12 »
no i dont work for valvoline......which is a shame as i'd get the oil even cheaper.... ;D
and the reason for the rave on about it its because it stops leaks from happening in the first place......
bloody amasing stuff......
