Author Topic: Matrix Fitted, But No Hot Air  (Read 1009 times)
Offline WhiteMk2Gti
« on: 11 June 2007, 16:28 »
All the hoses are hot, but not hot air coming out.
Ideas?
(brand new matrix fitted)
You know you want to, you dont realise it yet!
Offline monzablue16v
Re: Matrix Fitted, But No Hot Air
« Reply #1 on: 11 June 2007, 19:36 »
Bypass valve might have gone, it's in the engine bay just as the heater hoses go into the bulkhead to the cockpit. Try removing it and use a piece of hose or pipe to join it back together.
Offline MK4_20VT
« Reply #2 on: 11 June 2007, 21:41 »
Have you run the engine with expansion cap off? as this allows the trapped air to escape. You also will need to squeeze the top rad hose, to get the air out.
Jay
Offline Mr Blue
« Reply #3 on: 12 June 2007, 00:39 »
pull off the 2 hoses that go to the heater matrix in the engine bay.
get a hose pipe and shove it down one of the matrix pipes. Now open the tap and watch all the air escape the matrix. :cool:
once all the air is out, the water should flow freely out of the other matrix pipe.
Connect the pipes back. run the engine with the coolant cap off, hot heater blower on.
See if that works :cool:
Offline mattkh
« Reply #4 on: 12 June 2007, 08:57 »
Hi
Is the matrix bypass hose hot ?
Offline j_s
« Reply #5 on: 12 June 2007, 09:10 »
If you've put a new matrix in, you can also get rid of the bypass valves and use copper pipe or get some new rubber hoses.
James
Offline WhiteMk2Gti
« Reply #6 on: 12 June 2007, 10:11 »
ALL hoses (inc those going in and out of the matrix) are hot.
Will try the flushing matrix one as well.
Offline Lap
« Reply #7 on: 12 June 2007, 20:14 »
What about the flap on the fresh air box that diverts the air across the matrix when you require hot air? Does it move when you move the cold/hot lever? Check and make sure the cable hasn't come off or something.
