Author Topic: DSG GTi cutting out  (Read 1727 times)
Offline wilmo1979
DSG GTi cutting out
« on: 11 June 2007, 14:02 »
Hello all - new around here other than to say hello when I put my order in, hello again now shes finally arrived.
Just ticked over to 1,200 miles (2 months old) and has developed an infuriating fault: at low revs or idle in D, S, R or paddles the engine will just cut out completely and without warning, never had the problem if its idling in N or P, (first time this happened I was in the middle of the magic roundabout at Hemel, can't imagine much of a wose place to be with no engine!).  Will start again straight away (of course once N or P is engaged) with no problem.   Its maddening as it only happens now and again and inevitably it will behave when I take it back in to the dealers.... :angry:
Anyone else had similar issues or suggestions?
Matt
Offline RedRobin
Re: DSG GTi cutting out
« Reply #1 on: 11 June 2007, 19:18 »
Does the computer display anything in particular when the problem happens? Such as showing ALL selected? I had that and it was a failed Mechatronics Module on the DSG. Your dealer should be able to diagnose your fault very quickly.
Offline wilmo1979
« Reply #2 on: 12 June 2007, 22:01 »
No - nothing like that at all, no display warnings or anything odd  :sad:
Hope you are right about the dealer....
Thanks!
Offline Pabs32
  • Hello
« Reply #3 on: 12 June 2007, 22:09 »
Do you find it happens when the car is just warming up or does it happen when it's at normal operating temp ?
CW Ed30 3dr DSG, Xen, Highline, Satnav, IPod, Park sensor, Sunroof
Offline Hurdy
« Reply #4 on: 13 June 2007, 16:07 »
I had a problem with my last MKV DSG (albeit the diesel version). It kept cutting out just as I put more throttle on - does yours do the same?
   If so then it could be the ECU controller, as mine was replaced under warranty and there were quite a few threads on other forums quoting the same issues.
Seat Leon Cupra Black 290 DSG
Offline wilmo1979
« Reply #5 on: 13 June 2007, 21:28 »
Seems to do it hot or cold...
Sounds a bit more like Hurdy's problem although happens when I engage a "gear" rather than putting the throttle on.  Did you have any issues at higher revs?
Got to wait a week to get it into the dealers due to a shortage of courtesy cars...grrrr...
