Author Topic: Best oil  (Read 2494 times)
Offline e-lustrious
Best oil
« on: 12 February 2004, 21:55 »
This may have come up before but I couldn't be a***d going through all the pages...What is the best oil to use in my 8v.... :-\
    Cheers.
turbo
Re:Best oil
« Reply #1 on: 13 February 2004, 01:31 »
anything which is api, acea approved!
normaly says api sj or sl / cf..... acea A3/B3
valvoline maxlife---- semi synthetic.
valvoline durablend----semi synthetic.
valvoline synpower------ fully synthetic.
castrol rs ------fully synthetic
mobil 1-----fully synthetic
vw quantum synta gold----fully synthetic.
all of theses oils are very good....
i use valvoline maxlife........
on the valvoline website there are feedback from people who have used just valvoline in there cars and have got very high over (263.000) miles from there engines! so i neednt say anymore!
but most top synthetics are the same quality and there is no difference in engine wear tests!
mobil 1 vs valvoline synpower and it said on the net that synpower was better!
ive alwaysed used good oil in the gti and its on 197000.......
if it doesnt have api sj/cf acea A3/B3 on the back of the bottle it isnt any good!
abit like formula1 supermarket oils! 20w/50 nasty oil!
« Last Edit: 13 February 2004, 01:35 by vwsystems »
Offline cheech
Re:Best oil
« Reply #2 on: 13 February 2004, 09:11 »
Try putting in some slick 50 man, that stuff is the sh!t ;D
Offline GTI16vGaz
  • New car will be displayed soon.
Re:Best oil
« Reply #3 on: 13 February 2004, 11:22 »
Does any1 now exactly how much oil to put in a mk2 GOLF GTI16v.
My dipstick has been damaged and i'm not sure on the reading it may be wrong.
If i know the amount 2ltr etc... then i'll put that in..
Cheers,
Gaz
Offline cheech
Re:Best oil
« Reply #4 on: 13 February 2004, 12:00 »
To fill it from empty i thik its about 4.5L...it says somewhere in the haynes manual if you have one?
Offline m4nesh
Re:Best oil
« Reply #5 on: 13 February 2004, 20:54 »
I use Syntha Silver does the job and its only ?13 from the VW garage so its relatively cheap and it conforms to all those ABCDEF tests that vwsystems was on about in an earlier post 8)
turbo
Re:Best oil
« Reply #6 on: 14 February 2004, 01:34 »
its the same as the 8 v
with oil filter change 4.0 litres
without filter change 3.5 litres
from min to max on dip stick is 1 litre!
VeeDubGTI16v
Re:Best oil
« Reply #7 on: 14 February 2004, 13:46 »
vwsystems are you sponsored by valvoline?
turbo
Re:Best oil
« Reply #8 on: 15 February 2004, 00:10 »
 ;D ;D ;Dtheses valvoline questions  ;D
no i'm notnotnot! ;D i rave on about it because its good....good at stopping leaks and making a 197000 mile car go like the clappers! ;D
i'm sure this oil is the only thing keeping the engine from falling apart!!
