Author Topic: 60/40 split seats  (Read 1119 times)
Offline fused
60/40 split seats
« on: 07 June 2007, 20:16 »
Hey Guys and Gals, was wondering if there is any difference in a solid and a split rear seat set up? Ie different brackets, or fixings?
Ta
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
Re: 60/40 split seats
« Reply #1 on: 07 June 2007, 20:23 »
No just the covering caps on a split rear seat are different to a solid rear bench fix in exactly the same way
Offline Mew
« Reply #2 on: 07 June 2007, 20:28 »
I think the carpet is different too. Reason being there are 2 hinges on the 60 bit of the seat and 1 on the 40 bit, whereas the one piece bench has only 2 hinges.
Oh yeah, and i have one in the shed!  :wink:
Offline fused
« Reply #3 on: 07 June 2007, 23:17 »
so can you buy the hinges, or do you need to fabricate?
sharpie
« Reply #4 on: 07 June 2007, 23:23 »
should be hinges on the bench already, you might have an issue fitting it though.
Offline fused
« Reply #5 on: 07 June 2007, 23:35 »
..... you might have an issue fitting it though.
Why? :embarassed: really want to put the set in!
Offline Mew
« Reply #6 on: 07 June 2007, 23:47 »
Yep, hinges are on the seats. The holes will already be in the body so just a case of bolting them in. I suppose you could just make a couple of holes in your carpet.
« Reply #7 on: 12 June 2007, 11:22 »
the carpets have the holes in already, if you look in your car you'll see a plastic cover in the middle, remove this and holes for the middle hinges will be revealed :)
