Author Topic: ISV  (Read 2404 times)
Offline forzanerazzurri
ISV
« on: 12 February 2004, 08:46 »
i cleaned my isv bit it still didnt fix my idle problem, maybe it is not working and need replacing,  wasnt there a test of some sort? like unplugging it?? because when i unplug it the car stuggles and after a few seconds just stalls.  anyways is there a certain way to clean it casue i jst sprayed the carb cleaner insde bot hthe holes but not alot as i was scared of electrical connections (ie tilting it with he open ends facing upwards)  anyways if this dosent fix it, what else could it be?? o2 sensor?? is there a way to test that or maybe air flow meter?
'85 MK2 GTI BIGBUMPERS NeuspeedTurbo/SportSprings,Lowered 2"on15" BBSw/NittoTyres, PortPolish, Bored, 16VThrottleBody, NeuspeedShortShift, DubspeedBigBoreIntake, SwayBar, Racing
Offline GTi5
Re:ISV
« Reply #1 on: 12 February 2004, 09:27 »
I solved my idle problem on sat and all i did with the ISV was fully disconnect it and spray carb cleaner into it.  If the ISV is working it should buzz quietly when the ignition is turned on. Also try cleaning your throttle body out with cleaner too. It only takes half hour to do all.
Re:ISV
« Reply #2 on: 12 February 2004, 10:11 »
i hear a buzzing when i turn the key (not starting the motor) but it seems like a pump coming fomr behind the dash oddly
Offline richandhazel
Re:ISV
« Reply #3 on: 12 February 2004, 10:20 »
Got a bit of info here that might help you:-
http://www.richandhazel.servebeer.com/gti/mk2/fuel/main.htm#ISV
Offline VW2010
Re:ISV
« Reply #4 on: 12 February 2004, 10:21 »
When you first turn the ignition on, the sound you hear is the fuel pump!
Offline GTi5
Re:ISV
« Reply #5 on: 12 February 2004, 12:41 »
Put your finger on the ISV and you will feel it buzzing
