Golf mk2
the locknut from my tracking adjuster thing is missing!!!
Topic: the locknut from my tracking adjuster thing is missing!!! (Read 1497 times)
Mixologist
Guest
11 February 2004, 23:06 »
yep, the lock nut would be missing, anyone got any tips on how to replace it??
Last Edit: 11 February 2004, 23:08 by Mixologist
mk1
2ltr16v turbo (now with programmable EFI)
Re:the locknut from my tracking adjuster thing is missing!!!
12 February 2004, 19:16 »
Sometimes the track rod ends were "crimped" on one side. If you need to replace this type, you fit a complete arm. The other side should have the t.r.e with the lock nut on if.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
cheech
GTI forum regular
13 February 2004, 09:15 »
Quote from: Mixologist on 11 February 2004, 23:06
Yip....the right hand side track rod and track rod end are 2 seperate items which can indiviually changed! Te left hand side came as one unit from the factory which means having to change the whole track rod, the new ones have the replaceable track rod end......just make sure that you have got the same length when you put it back on. Replacing the track rod is a bit of a K*nt im afraid :-[
Golf mk2
