Author Topic: clutch noise  (Read 2892 times)
Offline adw555
clutch noise
« on: 03 June 2007, 19:54 »
if I'm in neutral and I let the clutch out I hear a little 'knock' noise ...is this normal. It's not hugely loud, but just wondered if it's anything to be worried about.
Offline wantmygti
Re: clutch noise
« Reply #1 on: 03 June 2007, 21:14 »
I hear it too. Most noticable on the first depress with the engine off before starting her up.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline adw555
Re: clutch noise
« Reply #2 on: 03 June 2007, 22:06 »
hmm...I only hear mine when the engine is on and idling...I was worried incase it was some sort of bearing noise.
Offline Teutonic_Tamer
Re: clutch noise
« Reply #3 on: 05 June 2007, 14:44 »
If my grey matter is woring OK, I'm sure this was discussed quite some time ago.  I don't think anyone reported further problems, so it may well be just a design quirk of the manual boxes.
How many miles have you all done?
I feel like a homo
Offline Creepy Coupe
Re: clutch noise
« Reply #4 on: 05 June 2007, 14:59 »
What happens if you press the clutch pedal down, does the noise go?
Phil mcavity
Re: clutch noise
« Reply #5 on: 05 June 2007, 15:25 »
Its most proberly the release bearing that is making the noise, normal in most cases, but should be changed when the clutch plate is replaced as good practice.
HTH
Re: clutch noise
« Reply #6 on: 05 June 2007, 15:33 »
I can understand a release bearing making a rumble type noise, but not a knocking, I was thinking of an idler shaft tapping. when their under no load they can chatter about a bit.
Phil mcavity
Re: clutch noise
« Reply #7 on: 05 June 2007, 18:04 »
if its just a slight knock as you press the clutch, its nowt to worry about!!
Offline adw555
Re: clutch noise
« Reply #8 on: 05 June 2007, 18:35 »
it's a brief slight knock/rumble when I let the clutch out at the very end of the clutch depress..doesnt stay on..and can only hear it when I'm in neutral and letting the clutch out...I guess it cant be much to worry about
