Author Topic: Dropping subframe  (Read 757 times)
Offline Barnzyuk
Dropping subframe
« on: 03 June 2007, 16:37 »
Hey guys, im having real trouble removing my downpipe. I've managed to get the 6 bolts undone that hold the downpipe to the manifold, and im now trying to remove it from the car. I've removed the 4 bolts holding the subframe up and dropped it as far down as i can I also removed the bolts at the bottom of the struts to see if that helped, but i cant get the subframe low enough to remove the downpipe. anyone got any ideas??? :nerd:
The Steak 5.0
VeeDubGTI16v
Re: Dropping subframe
« Reply #1 on: 03 June 2007, 18:38 »
the steering rack will be holding it up you might have to undo it
Offline ...joe
« Reply #2 on: 03 June 2007, 20:55 »
pull the manifold out from the top?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Barnzyuk
« Reply #3 on: 04 June 2007, 02:12 »
I tried getting it out through the gap above the gearbox with no luck, as the gear linkages got in the way. Ill have a go at removing the steering rack and seeing if that gives me enough clearence. Now wheres my haynes manual..... :nerd:
The Steak 5.0
Offline matg340
« Reply #4 on: 04 June 2007, 06:43 »
it comes out from the bottom m8y ! you shouldnt have to remove anythin there just a b!tch to get out you need to twist the downpipe as your pulling it down i cant remember exactly how they come out but it will be that way !
brute force and ignorance is the way m8y even with a ramp there sh!te to get off
preserve wildlife.......PICKLE A SQUIRREL !!!!!!!!!!!!
