Author Topic: Uneven tyre wear?  (Read 1817 times)
Offline Mart8V
  • I really should know better by now.....
Uneven tyre wear?
« on: 03 June 2007, 11:59 »
Have just swapped my tyres front to back and noticed that both fronts are heavily worn on the inside, almost to being bald.  Have only had them on the car since Feb.
What is causing this?  Car is lowered by 40mm, but is a late Mk2 without the camber adjustment.  It also pulls a little to the left.....
Help, please!
Offline Ashmond
  • Money, b!tches And Boost
Re: Uneven tyre wear?
« Reply #1 on: 03 June 2007, 12:00 »
Get your tracking sorted out mate, its about 30-40quid normally
Offline Mart8V
« Reply #2 on: 03 June 2007, 12:09 »
Thought that might be it, but only had it done three months ago.  Bugger......
sharpie
« Reply #3 on: 03 June 2007, 14:19 »
what tyres you using? mind by having it lowered you should expect a lot more inside wear because it increases the camber anyway.
Offline Mart8V
« Reply #4 on: 03 June 2007, 20:16 »
Have Toyo Proxes on all four.  Didn't have this problem with the Goodyears on the last Mk2 (suspension swapped over), but then this one seems to sit a lot lower for some reason.  Curious.
Will get the tracking checked anyway.
Offline Gene Hunt.
« Reply #5 on: 25 July 2007, 16:40 »
If you can find a garage that has the lazer tracking.Had mine done 3 weeks ago & what a difference.
Candy White ED35.
