Author Topic: Mk3 8v gearbox on Mk2 8v? Does it go?  (Read 941 times)
Offline benross
  • Watch this space!
« on: 01 June 2007, 09:37 »
Hi all,
I dont know if you've seen my other post about my gearbox / syncramesh probs but I may have a solution.
If its not so easy to fix I have a spare gearbox from a mk3 8v gti. It came with an engine I bought for the bottom end for one of my other mk2s. Would this gearbox (which is rod not cable) fit on a 1989 mk2 8v without having to buy any other bits?
Help appreciated- maybe rubjonny might know- he seems a whizz anything mk2.
Digi 8v restoration project
Kjet 8v runaround
'86 T25 Camper
Re: Mk3 8v gearbox on Mk2 8v? Does it go?
« Reply #1 on: 01 June 2007, 10:32 »
no its not a direct fit, you wopuld need a 16v clutch friction disc as the input shaft is bigger.  The ratios 2-5 are taller as well, might not be a good match for the lower torque on the 1.8 8v!
Offline benross
  • Watch this space!
« Reply #2 on: 01 June 2007, 10:47 »
Thats a bugger then. Have you any ideas on.....
http://www.golfgtiforum.co.uk/index.php?topic=60340.0
As it might not even need a new box.
Cheers mate
Kjet 8v runaround
'86 T25 Camper
« Reply #3 on: 01 June 2007, 11:22 »
yes ive already replied to that one  :grin:
Offline moonsta
« Reply #4 on: 01 June 2007, 16:22 »
 am about to break an '89 8 valve with tried and tested box, if that's any good to you?? am in hertfordshire..... £50:00.
Drives '96 Polo 6N and '85 Mk Golf Gti...
