Author Topic: High idle on hot start?  (Read 784 times)
Offline Dark_Seraph
« on: 31 May 2007, 19:57 »
Hey all!
I've just joined the ranks of the priviliged after buying a 1986 8v GTi, but i've only had it a month, so please excuse me if this is a noob question!
Basically, whenever I cold-start the car it idles fine, but if I turn the engine off and then back on again within about 10mins, it idles at around 2000 until the oil reaches 80deg or so. The oil temperature gauge is a bit dicky and quite often does'nt work, could this be related?
The car is stock other than a Pipercross air filter.
Any ideas?
Thanks!
Offline Dark_Seraph
Re: High idle on hot start?
« Reply #1 on: 31 May 2007, 20:14 »
Oooop, I meant 1989, hehe.  :rolleyes:
« Reply #2 on: 01 June 2007, 10:54 »
check out the idle switch, replace the blue temp sender, and tune it as per my digifant FAQ :)
