With the 6 CD changer plugged in you should be able to use it. The restriction is you cant use the UNIT DVD/CD slot while using navigation. The software uses the DVD in the slot rather then loading it all up.
So you should be able to use the changer as long as you dont have an ipod adapter on the same interface.
Dave N
