Author Topic: GTI knock sencor  (Read 2188 times)
Offline ken
GTI knock sencor
« on: 11 February 2004, 07:12 »
Can anyone please tell me what the knock sencor is ment to do,that is fitted to the outside of my engine block at the front.(this is to the left side of the oil filter)
The car is a MK2 1990 gti jetta,sorry i cant read the engine code number that might help. 8)
ken
golfvr6
Re:GTI knock sencor
« Reply #1 on: 11 February 2004, 09:06 »
The knock sensor senses pre-ignition(pinking or knocking) and retardes the ignition timing accordingly.
Do you have a problem with it?
Offline richandhazel
Re:GTI knock sencor
« Reply #2 on: 11 February 2004, 13:12 »
Spot on as always '6 ;)
Offline ken
Re:GTI knock sencor
« Reply #3 on: 12 February 2004, 06:08 »
The answer may be, the car runs fine 99% of the time but now and then the car seams as its being starved of fuel,i get a jerking when under hard use of the throttle.If i take my foot of the throttle then straight back on again its works fine.
Many thanks for the reply.
turbo
Re:GTI knock sencor
« Reply #4 on: 14 February 2004, 01:19 »
this just controls the ignition timming if pinking is detected it ajusts.....
fuel starvation...... how long is it since your fuel filter was replaced!
your jerking problem may be something to do with the throttle switchs on the throttle check them out for snapped wires etc....... you should have 2 of theses 1 under the throttle and 1 on top to check the 1 on top start car up and turn the throttle and then press the switch if the revs die down the switch is working.....
Offline ken
Re:GTI knock sencor
« Reply #5 on: 17 February 2004, 17:57 »
cheers scatmam john
ken
turbo
Re:GTI knock sencor
« Reply #6 on: 18 February 2004, 00:40 »
scabbaloneebeep beep! skrimlebap burlebop!
scat language! noo problemmo!
do you speak scat! ;D ;D
