Author Topic: odd misting of oil  (Read 773 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
odd misting of oil
« on: 29 May 2007, 22:19 »
Strange oily substance like what id imagine to be in a catch tank, It's odd, its all over the rubber carb flange on the servo feed side mainly, all over the inlet manifold and has been running or dripping down to, tis all voer the oil seperator tube which makes me think its misting out of there cause the pipes rotten through maybe? or its sucking sh!te into the servo and then misting it back out  :undecided:
its the same substance my pre ehater gasket seemed to be covered in when i ahd it out, theres a bolt msising from the preheater to, needs to be put in asap, and im thikning of maybe renewing the gasket, or should i renew the pipe as its very cracked and weathered on the outside, or is my seperator buggered?  :sad:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
