Author Topic: MK3 Side Trim  (Read 1606 times)
Offline Ivlatt
MK3 Side Trim
« on: 29 May 2007, 00:02 »
Yes yes
Just enquiring if you any1 knows where I can buy replacements for the side trim? (the standard black trim that runs down the side) of teh mk3.
Seen a couple of white golfs with the standard trim replaced with white and,, I like  :cool:. Checked Ebay, no luck.  :sad:
Offline garfayliu
Re: MK3 Side Trim
« Reply #1 on: 29 May 2007, 00:18 »
breakers yard, or as you're doing already, here on the forums. they're quite dear from VW. alternatively you can smooth yours, and spray them any colour.
Offline Len
Re: MK3 Side Trim
« Reply #2 on: 30 May 2007, 11:14 »
The standard is 63mm wide and has a rough finish.
You can also get the GL type ones which are 53mm wide and are available in a rough finish or smooth called painted.
A full set of the 53mm can be purchase new from ECP or Main VAG Dealer.
www.sas.org.uk
www.the-ace.org.uk
