Author Topic: Gti calipers  (Read 1476 times)
Offline owls88
Gti calipers
« on: 27 May 2007, 14:34 »
would gti calipers fit stright onto my 1.3 on the front , or would i be better just uprating the disks and pads using my 1.3 calipers ?
Offline Gambit
Re: Gti calipers
« Reply #1 on: 27 May 2007, 15:28 »
im near enough sure the 1.3 has solid front disks whereas the 8v GTI has vented, but they are both 239mm
so u would need GTI Calipers & Gti Disks & GTI pads.
it would be a very cheap upgrade as u can pickup 8v GTI calipers for buttons
Offline Mew
Re: Gti calipers
« Reply #2 on: 27 May 2007, 15:31 »
I presume the 1.3 calipers are the same as the 1.6 driver's, in which case i belive you can just replace the solid discs and appropriate pads with vented gti discs and pads to suit.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Gti calipers
« Reply #3 on: 27 May 2007, 15:51 »
Yep, AFAIK you can...
Add the new discs with the pads to cuit, as the GTI pads are thinner but the discs are wider and vice versa but the diameter is the same, rubjonnys told me this orgiinally so I'd trust it  :grin:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline owls88
Re: Gti calipers
« Reply #4 on: 28 May 2007, 00:28 »
ive been offered some gti calipers (16V 239mm) would i be able to fit these stright away with uprated disks and pads then
  NTR477DG  Nitrac Drilled + Grooved Discs  Golf Mk2 GTi 1.8 16v 8/88>7/92  £125.52  £112.9
  TRX-0221S  Tarox Discs - Sport Japan - Front  Golf Mk2 1.8 GTi 16V 10/88>91  £157.45
bearing in mind my car has no ABS
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: Gti calipers
« Reply #5 on: 28 May 2007, 00:39 »
you sure theyre 239's? Would depend on what year 16v they came of wheter they are 239 or 256's. After 8/88 16v's came with the larger discs, and to use these you need later spec 16v hubs. The discs and pads youve put up WONT fit a car that originally had 239mm brakes but your cvalipers might fit your car (caliper year dependant). If you dont know the size of brake the caliper is for just stick with 8v calipers, as the are all 239's.
oh, and no mk2's had abs iirc, makes it more fun when you lower it and dont change the bias as rear wheels lock up first  :evil:
hope that helps.
Re: Gti calipers
« Reply #6 on: 28 May 2007, 10:52 »
didnt that limeted edition with teh blue grille one have abs?
i want one of those  :sad:
Quote
Offline Gambit
Re: Gti calipers
« Reply #7 on: 28 May 2007, 13:18 »
all G60's came with ABS be it a standard G60, Rallye, or G60 16v (limited)
VeeDubGTI16v
Re: Gti calipers
« Reply #8 on: 28 May 2007, 13:21 »
i have a 16v setup for sale, hubs callipers discs and carriers for cheap
Re: Gti calipers
« Reply #9 on: 30 May 2007, 14:02 »
Gambit: All MK2 239 calipers are identical, no need to swap them to fit GTI 8v discs & pads.  However you will need longer caliper bolts for a 1.3 as one of them is too short (bottom one from memory).  For 1.6 on though you don't even need the bolts as they are the same length.  Its a good idea to get new bolts either way though as they tend to be buggered on MK2s :grin:
owls88: 256mm brakes only came on 90 spec 16vs. As well as Rallye, limiteds & G60 MK2s there were a few 'normal' MK2s equiped with ABS, but these are VERY rare :)
