Author Topic: Tyre Pressures -What do you run at?  (Read 5030 times)
Offline Blowers
  • Laser Blue Golf GTI
« on: 27 May 2007, 12:57 »
When I bought my 18 mth old GTi from VW  I assumed (wrongly) the tyre pressures would have been checked. This was not the case and when  I checked (after the tyre pressure light came on) each of the tyres was completely different but all well under the recommended levels . Oddly I could not tell they were different as the ride was fine. I have now taken up to the recommended 2.4 bar which equates to 36psi and I don't like the ride - very hard- picks up all the bumps etc .
I was just wondering whether anyone has had experience of consistently running below the recommended pressure levels to get a softer ride and if so by how much. I have no intenion of kn.ck.ring the tyres
Thanks (Cass thanks also for your general advice )
Continetal sportscontact2 -normally just me and the golf clubs
Phil mcavity
Re: Tyre Pressures -What do you run at?
« Reply #1 on: 27 May 2007, 15:36 »
i run at 43 psi in the front and 37 psi in the rear from T.T's advice on best setting and even tire wear and have to say since setting to that, cars been handling great using Bridgestones
Offline symonkey1
« Reply #2 on: 27 May 2007, 16:05 »
Ive been putting mine to watit suggest on inside of petrol cap.
Offline SteveS
  • GTI ED30
« Reply #3 on: 27 May 2007, 19:03 »
43 sounds a bit much if 36 is recommended??
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline Blowers
Mark 5 Tyre Pressures -What do you run at?
« Reply #4 on: 30 May 2007, 23:55 »
Any other input as not sure what conclusion to arrive at from this
Offline aahgolf
« Reply #5 on: 31 May 2007, 07:13 »
I run mine at the specified settings. If you overinflate the ride is even harder and the tyres will wear differently than they should, and if you underinflate it helps the ride but then I would be concerned about the effects of driving fast, as you then are not running the tyres as the maker specified and grip and handling are bound to be different.
When the police investigate accidents, they do check tyre pressures and to make an extreme point, if they found that the tyres were running at very low pressure then there would definitely be some element of blame attached to the owner. The same could be said for pressures too high.
I dealt with the ride on my car by having Koni FSDs fitted. Not cheap but brilliant. Hope that helps!
Steel Grey 05 GTI, 3 door, manual, MFD2, 6-CD, sunroof, parking sensors, winter pack/heated seats, lux pack 2, folding mirrors, Koni FSD
Offline Hully
  • GTI Edition 30, Reflex Silver - May 07
« Reply #6 on: 31 May 2007, 14:17 »
I've set mine to manufactures spec, which I seem to remember is 2.6 bar or 37.5 PSI  (I've put 38 PSI in as I haven't got an acurate guage down to 0.5 PSI) all round.  Too early to tell the effects due to running the car in. I also seem to remember somewhere that you can vary from the manufactures recommended pressure by about 4 or 5 PSI and still be fine from a legal point of view. Also, when fully loaded the recommended is 2.8 bar so there is a little bit to play with there.  :nerd:
MkIV GTI PD150 sold, now FOR SALE MkV GTI Ed30, Reflex Silver, 07, manual, 5 Dr, 29.5k miles, 1 owner from new, xenons, cruise, park sensors, ugraded VW stereo and sound system, MFSW, Armrest, sunroof, immaculate never raced or thrashed, totally original, For Sale - PM me for details.
Offline Teutonic_Tamer
« Reply #7 on: 04 June 2007, 13:19 »
Blowers, and everyone else too . . .
The tyre pressure sticker on the fuel filler flap is just "recommended" tyre pressures, and do not form part of Moses 10 commandments.  :wink:
These are set for Mr and Mrs Average (weight), driving on average roads, with an average driving style.  Furthermore, they are an average pressure to cope with the different range of tyres (from different manufacturers) that may be fitted.  Finally, they are an average compromise between handling performance, comfort, and economy.
OK, it is very, very wise advice to always start with the "recommended" pressures, and run the car for at least 500 miles to allow the tyre treads to "bed-in".  However, you are perfectly free to "tweak" the pressures to your own particular preferences.  A word of caution, though - I would strongly advise on not going any more than 3 or 4 psi below the recommended setting, due to excessive heat build up, and the very real risk of blow-outs.  Increasing from the recommended - then the sky is your limit, though I would recommend stopping at 50psi on a car!  :wink:
When checking tyre pressures, do NOT use a garage airline, as these are notoriously unreliable.  Invest in a quality PCL type pencil gauge, or a quality round dial or digital type, and only use that.  Also, do not check your pressures if you have driven the car, nor if the tyres have been baked in the sun.  Ideally, the best time to check your pressures is first thing in the morning, before you drive to work/shops/nursery (gotta put that last one in there, to keep the fairer sex happy!  :wink:  :kiss:).
If you do feel the need to make your own personal tweaks, try to increase (or deacrease) in steps of about 4psi at a time - and give it at least another 500 miles before confirming if the adjustment is OK for you.  If you do find a revised setting you are happy with, then make sure you write it down (on a business card or sommat), and keep it handy, ideally with the handbooks.  Finally, when the car goes in for servicing - TELL them not to alter your preferred tyre pressures.
Once you have reached your own "adjusted" tyre pressures, every 1000 miles or so, carefully measure the tread depth, across the entire width of the tread, with a proper tyre tread depth gauge - just to make sure they are wearing evenly.
Another issue, you may feel the need merely to tweak the front tyre pressures, and leave the rears as standard - which is also fine.  If anyone wishes for further detailed advice on how to set up tyre pressures, then ask away!
One point on the "legal" issue - tyres only need to be "adequately inflated", therefore, pressures again do not need to match the recommeded pressures.
Onto the comfort issue.  Blowers, you mention that you have Conti SportContact2s - unfortunately, these are well known to produce quite a harsh ride at slow speeds.  However, on the flip-side, they are truely rock-solid (stability wise) at extremely high autobahn speeds.  Unfortunately, until they wear out, you will probably have to put up with them.  However, come time to change your boots, then either Michelin Pilot Sport PS2, or if you are less Michael Shumacher, and more Micheal Winner in your driving style, Michelin Pilot Exalto PE2 give a noticeably softer ride than your Contis.
I feel like a homo
« Reply #8 on: 04 June 2007, 13:23 »
That's good to know.  It would seem that the Bridgestones have similar handling characteristics to the Dunlop ShyteMaxxes, then.  What about your own wear patterns though?
I feel like a homo
Offline Blowers
« Reply #9 on: 06 June 2007, 11:46 »
TT-excellent
Many thanks
