Author Topic: turbo kit for 8v  (Read 1007 times)
Offline markmarky0
turbo kit for 8v
« on: 27 May 2007, 11:47 »
http://cgi.ebay.co.uk/VW-GOLF-MK1-MK2-8V-TURBO-KIT_W0QQitemZ330125440141QQihZ014QQcategoryZ9889QQrdZ1QQcmdZViewItem
click the link above : just wondering is this actually possible ? and wat sort of power u think an 8v might get ?
cheers
mark
Offline fused
Re: turbo kit for 8v
« Reply #1 on: 27 May 2007, 11:58 »
Looks interesting! It looks like a one off kit, thats been used. Would need to upgrade fueling (new ecu/chip?) would need to run low boost unless you did some serious internal work, since most mk2 have quite high mileage. would you need to lower compression? The guys at Jabba sport might be able to set it up and recommend fueling and spot other potential problems.
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #2 on: 27 May 2007, 19:18 »
wouldnt of thought you could run much boost without at least using a spacer plate to lower compression a bit. would also need some form of uprated management as earlier said,, think you could run it with a G60 ecu iirc.
Offline Mr Blue
« Reply #3 on: 28 May 2007, 12:48 »
no point fitting a turbo and not uprating the internals.
low boost is pants
