Author Topic: Can only select first when stopped?  (Read 1891 times)
Offline MK4_20VT
« on: 10 February 2004, 14:07 »
When the car is cold, i have to stop before i can select 1st gear (or apply loads of force & 5 sec l8r it engages).
This problem goes away when the car warms up (25mins driving)
I'v had my gearbox reconed 2 weeks ago, the box is better but i still have this getting into first problem
Also i did replace the white plastic ball joints
What could be wrong? as i don't have the problem selecting reverse instead of 1st????
Help guys
golfvr6
Re:Can only select first when stopped?
« Reply #1 on: 10 February 2004, 14:37 »
If the box has been replaced then the linkage could well be out of adjustment.
Offline MK4_20VT
« Reply #2 on: 10 February 2004, 14:48 »
With the risk of being stupid, If the gear linkages were out would this not happen 2 me all the time & not just when the car is cold  ???
golfvr6
« Reply #3 on: 10 February 2004, 14:51 »
No the gearchange can improve when the car warms up. If the gearchange was ok before the box was reconned then get the adjustment checked. Also check the bushes.
Offline MK4_20VT
« Reply #4 on: 10 February 2004, 14:58 »
This problem existed before the gearbox was removed, but i will get the bushes checked this weekend err (is this were you remove the gator etc) or something completly different  ???
Offline crimp
« Reply #5 on: 10 February 2004, 19:41 »
mine is the opposite, when cold 1st is realy easy to get in but when warm I have to force it. Dose not make any sence to me?
