Author Topic: mk2 16v leaking water  (Read 793 times)
Offline Bigdunc
« on: 25 May 2007, 08:50 »
hi my mk2 16v broke down yesterday it's leaking allot of water seams to be coming form the main engine block . the water hasn't mixed with the old so possibly not the head gasket. i cant quite see the leak as the cam belt is in the way but you can hear a squeaking noise and  and see water coming out when you squees the water pipes.
does anyone have any ideas what it could be
thanks
Offline DarnPB
  • Formerly Darnpistonbroke
Re: mk2 16v leaking water
« Reply #1 on: 25 May 2007, 08:52 »
Possibly your water pump has gone for a pearler.
Offline Gambit
« Reply #2 on: 25 May 2007, 08:58 »
yeah it'll be the water pump. not too bad a job to sort
Offline Bigdunc
« Reply #3 on: 25 May 2007, 09:22 »
i thought the water pump was at the bottom of the engine as this leak is at the top, as i thought waterpump and then realized the leak was at the top on the engine.
Offline Gambit
« Reply #4 on: 26 May 2007, 12:40 »
if its the top then i can only assume its blown the headgasket
