Author Topic: Taking rub strips off?  (Read 1342 times)
Offline jimmy1182
« on: 24 May 2007, 14:09 »
Hey all,
I'm thinking of taking off the rub strips off my 87 3dr 16v, anyone any ideas whether it is clipped on or glued on? I'm sitting in work thinking about it so cant get too the car.  :laugh:
Also, will it look stupid taking the strips off and leaving the arches on as they have the bit which lines up to the rub strips?
Has anyone done it and had good results?
Offline Gambit
Re: Taking rub strips off?
« Reply #1 on: 24 May 2007, 14:30 »
they are clipped in so you'll have holes along the side of your car if you remove them
Offline j_s
« Reply #2 on: 24 May 2007, 14:59 »
As above, taking mine off when I get car resprayed in a couple of years I think  :smiley:
James
Offline jimmy1182
« Reply #3 on: 24 May 2007, 15:13 »
ah well, there goes that idea then  :sad:
taxiboy
« Reply #4 on: 24 May 2007, 17:37 »
if your car has the deep sidestrips finding a narrow set is quite effective
Offline curlie467
« Reply #5 on: 25 May 2007, 14:52 »
They are glued on earlier models, mine was a 1987 16v and they were glued on. Take your door cards off and if there are no clips popping through then rip em off. Getting the glue off is a pain in the arse though.
Offline jimmy1182
« Reply #6 on: 25 May 2007, 15:55 »
is there any sort of cleaning solution that can take the glue off, it mine are glued on, withouth killing the paintwork?
Or is it down to the technique of taking it off. I learnt the hard way many years ago when doing a similar job on my old XR2  :embarassed: shameful i know, and took off loads of the paint
Offline jammac
« Reply #7 on: 25 May 2007, 16:05 »
TSK! fords!  :sick:
ITS A TRAP!
Offline jimmy1182
« Reply #8 on: 25 May 2007, 16:22 »
 :embarassed: i know, i was young and stupid, soon learnt the error of my ways though
No going back now, my VW collection is growing and growing, at the last count '87 16v GTi, 1980 Camper and 1990 Driver (collecting dust in the garage)  :smiley:
Offline Gambit
« Reply #9 on: 25 May 2007, 16:42 »
if they are glued on then run a hairdryer or heat lamp along the length of them to soften the glue, then get a piece of fishing line and pull it through behind the trims.
left over glue can be removed with tar remover or petrol
also, if u take them off u will still have the holes there?!?
