Author Topic: Wheel spacers  (Read 875 times)
Offline dubsport
  • TDI POWAR!
Wheel spacers
« on: 24 May 2007, 11:44 »
before i lower my car i was thinking of filling out the arches, im guess you have to use wheel spacers ... ? could someone tell me if this is the kinda thing il need .... http://cgi.ebay.co.uk/20mm-spacer-kit-VW-4-hole-golf-mk1-mk2-polo-jetta-kit2_W0QQitemZ300111740887QQihZ020QQcategoryZ122154QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
thank you  :smiley:
Offline boneybradley
  • Back in a Mk3...
Re: Wheel spacers
« Reply #1 on: 24 May 2007, 12:00 »
they would work but i recommend hub centric one's to stop wheel wobble... as this kit uses universal spacers with special stud's they don't allway's fit right
Offline Organisys
  • Old and Slow...
Re: Wheel spacers
« Reply #2 on: 24 May 2007, 12:09 »
As above.
Offline Gambit
Re: Wheel spacers
« Reply #3 on: 24 May 2007, 14:31 »
Re: Wheel spacers
« Reply #4 on: 30 May 2007, 16:05 »
Depends on the depth of the spacers, but 20mm non-hubcentric will be too long for a VW.  10mm non-hubcentric spacers at the rear is ok, as there is enough of the lip sticking out to centre the wheel, but up front it'll need to be more like 5mm or so!
Any thicker than this and you need hub-centric spacers.  Also note that hubcentric spacers smaller than 12-15mm or so wont fit over the hubs properly, as I found out to my annoyance the other day! :grin:
