Author Topic: Engine running rough...  (Read 923 times)
Offline richw911
« on: 23 May 2007, 20:03 »
Hi i have a mk3 2.0 16 on a L reg, The engine runs rough sometimes and it will also cut out, or try to cut out. Has anyone got any idea what could be wrong, as i dont want to spend pounds fitting new parts that i dont need!!  :angry:
Cheers Rich.
« Last Edit: 23 May 2007, 20:57 by richw911 »
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: Engine running rough...
« Reply #1 on: 23 May 2007, 22:57 »
Well the first thing i would do is clean/have cleaned the throttle body as this tends to cake up with carbon deposits, also check your vacuum lines as these tend to disintergrate over time!
When did you last have it serviced..? old plugs, dirty air filter...could be any number of things. Also id recommend either running a couple of tanks of v-power or use some redex to help clean the injectors.
