Author Topic: Intermittent Power and oil light and buzzer!??  (Read 931 times)
Offline Trigger1002
« on: 23 May 2007, 10:49 »
Just bought a mk2 8v (G Plate) and have a small prob that I'm after a bit advice on:- Driving between about 30 - 60 if I keep my foot constant on the accelerator the car will take power then stop taking. Makes for a pretty lumpy ride, just wondering if anyone has any advice/experience they can pass on? Thanks  :grin:
« Last Edit: 26 May 2007, 12:59 by Trigger1002 »
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Intermittent Power!??
« Reply #1 on: 23 May 2007, 18:49 »
What system is the car running? K-jet or digifant?
Offline cняis
« Reply #2 on: 23 May 2007, 20:16 »
it will be a digi if its a G plate
Offline Trigger1002
« Reply #3 on: 24 May 2007, 01:11 »
i believe like crevice says its a digi....
Offline fused
« Reply #4 on: 24 May 2007, 01:25 »
try this topic for all your digifant woes  :laugh:
http://www.golfgtiforum.co.uk/index.php?topic=33253.0
Offline Trigger1002
Re: Intermittent Power & oil light & buzzer!??
« Reply #5 on: 26 May 2007, 12:53 »
Thanks for the suggestion, however - when the engine is up to temperature if I turn it off and restart it, it fires straight up to 2000 rpm and the oil light & buzzer comes on. If i let it cool down a bit it will fire up at the usual 700 rpm & I can drive it fine until it reaches temperature, then it all starts again....any ideas??
Offline DarnPB
Re: Intermittent Power and oil light and buzzer!??
« Reply #6 on: 26 May 2007, 16:25 »
Try and change your blue temp sensor and check the oil level first. You may just have a dodgy oil pressure sensor.
Offline Trigger1002
« Reply #7 on: 27 May 2007, 11:57 »
Thanks, already checked the oil and gave it a top up - will try the sensor but can't get that til tues now  :angry:
