Author Topic: Radiator Thermoswitch. Which one???  (Read 986 times)
Offline frog
« on: 21 May 2007, 21:05 »
93476 RADIATOR THERMO SWITCH  G3 11/91 >7/93 2 Pin with Cover 95/84C  6.25
93478 RADIATOR THERMO SWITCH  G3 11/91 >7/93 3 Pin with Cover  7.95
93479 RADIATOR THERMO SWITCH  G3 3 Pin with Offset Pins  8.50
93480 RADIATOR THERMO SWITCH  G3 8/93 >2/99
Which of the above switches from GSF is the correct one for a '94 1.4cl?
The switch currently fitted is a 3 pin switch but not sure if it is 'with cover' or 'offset' any one shed any light of the subject as at the moment i have 2 wires shorting the switch out, but this means that the fan is running at the fastest setting all the time and i have to connect the wires as soon as i start and as soon as i stop.
Please help!
Offline raylee25
Re: Radiator Thermoswitch. Which one???
« Reply #1 on: 21 May 2007, 21:34 »
The best thing to do is to go to your local vw dealer and ask them for the part no. then go to gsf. as gsf use the same part number.
Offline frog
« Reply #2 on: 21 May 2007, 21:40 »
When i went to my local dealer they didn't stock them, even he said that it might be one of 2, just thought someone on here might be able to help me out
Offline raylee25
« Reply #3 on: 21 May 2007, 21:50 »
They should be able to find it wuth an engine code
Offline frog
« Reply #4 on: 22 May 2007, 21:01 »
managed to locate the part number by removing the switch.
IH0 954 481B, H3, 95* and 102* 3 pin switch
how do these numbers convert to part number?
Offline frog
« Reply #5 on: 22 May 2007, 21:21 »
Its ok now, part found and ordered from http://www.vwspares.co.uk/ for £10 less than Stealership
