Golf mk3
hardmonkeys
Changing a speedo
Topic: Changing a speedo (Read 1148 times)
guyn17
Changing a speedo
21 May 2007, 18:10 »
Hi there, just wondering how easy it is to change the speedo dials, the whole unit that is? also is it possible to change the mileage on the unit that goes in so it matches the true mileage of the car? any help would be much appreciated!
-scott-
Re: Changing a speedo
21 May 2007, 22:14 »
its really easy to change the speedos over.Pop the plastic off either side then 2 screws to take the black part around the dials off then its just a matter of another 2 srews holding the dials themself in.Once they are out its just a matter of diconecting one cable and fidling the whole thing out.Pretty simple to do.
The milage thing though im not so sure about as i was wanting to change mine with another but the milage stayed the same from the car the other dials came out of.
Mrk 3 Golf VR6 Colour Concept
phil_a
GTI forum regular
21 May 2007, 23:02 »
hi, sorry for the hijack but i was just wondering if doing this would allow you to change the backlight for the clock/mfa display as mine needs doing or is it more complicated?
many thanks, Phil
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
22 May 2007, 08:56 »
To change the mileage...all you need is access to vag-com (or know someone that has)..... and to replace bulb's all you need to do is remove the clock's as above and then split them (just a few pushy thingy clip's to undo)
phil_a
GTI forum regular
22 May 2007, 23:22 »
thanks bradley will have a go at the weekend.
Golf mk3
hardmonkeys
Changing a speedo
