Author Topic: abf with mk2 gearbox  (Read 1428 times)
VeeDubGTI16v
« on: 20 May 2007, 10:29 »
if im putting the gearbox from mk2 16v onto an abf which flywheel and clutch do i use? im guessing the mk2 ones?
cheers
Offline ...joe
Re: abf with mk2 gearbox
« Reply #1 on: 20 May 2007, 18:17 »
pretty sure you use the gearbox matching one, so in your case the mk2 16v clutch and flywheel.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
« Reply #2 on: 21 May 2007, 12:22 »
Yep mk2 bits :)
As you'll no doubt see when you get the ABF lump, the flywheel & clutch setup is totally different on the cable change boxes.
VeeDubGTI16v
« Reply #3 on: 21 May 2007, 13:03 »
ok, cheers guys!
what about the rad, will the mk2 one be up to the job?
« Reply #4 on: 21 May 2007, 13:07 »
the 16v one is a bit small, you might have to think about upgrading to an 8v item!  The 16v ones are double cored though so you may be ok, but I'd upgrade to a 2 speed fan at least!
On the 'other' forums the track day guys get good results from the 8v rads.  If you do go for an 8v rad you may need the hoses to go with it though!  Oh and be aware that the lower rad pipe from the ABF may not work becasue the thermostat elbow is different on MK3s, but fit your old MK2 one and you should be reet.  Might as well put a new stat & seal in while yr there :)
VeeDubGTI16v
« Reply #5 on: 21 May 2007, 13:11 »
jonny, you really need your own mk2 garage fella :laugh:
yeah will put on new stat, my rad i got now has a leak thats been radwelded so ill be buying a new one for this engine, might go for a pair of those slimline fans as well :cool:
« Reply #6 on: 21 May 2007, 13:24 »
if you can stretch to it look into MK2 diesel or aircon rads, bigest you'll find :)
VeeDubGTI16v
« Reply #7 on: 28 May 2007, 13:56 »
what clutch would you recommend?
Offline Daz...
« Reply #8 on: 29 May 2007, 09:31 »
I've got a standard 16v clutch in mine, seems fine for everyday driving. If you're planning on taking it on the track or strip then it would be worthwhile getting an uprated one.
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
VeeDubGTI16v
« Reply #9 on: 29 May 2007, 19:22 »
i wont bother with the strip but trackdays are definately on the cards :evil:
