Author Topic: Where is my isv on a mk2 16v  (Read 2330 times)
Offline Danr
« on: 19 May 2007, 14:35 »
Ok got an isv of a lad on here but it doesent seem to be whats on my car so not dure if im lookin in wrong place.
heres whats on my car.
and here is what i got.
So where am i going wrong?
Offline Danr
Re: Where is my isv on a mk2 16v
« Reply #1 on: 19 May 2007, 20:49 »
A couple of bigger pics, so any help appreciated, its an early 16v as well.
Offline rowlers
  • I'm back - MK7 GTI
« Reply #2 on: 20 May 2007, 09:04 »
in the pic above follow the HT leads in their plastic cover from left to right, at the right hand end of the plug leads, you will see the ISV, its got an electrical connector on the back, a vacuum connector on the front and another vacuum underneath.
hope this helps.
Edit:
not sure what is going on with your car - no idea what those pics show, has you ISV been bypassed or something???
« Last Edit: 20 May 2007, 09:07 by rowlers »
Offline curlie467
« Reply #3 on: 20 May 2007, 13:00 »
The more i look, the more i think it has been bypassed aswell. I supplied new bits for danr but as his is different its a struggle to work out how to install it.
Offline Danr
« Reply #4 on: 20 May 2007, 14:26 »
Well the engine pic in rowlers post looks nothin like mine, the black pipe from the air box going across the top of the rocker cover to the isv isnt on mine, so im gettin lost.
Offline clipperjay
« Reply #5 on: 20 May 2007, 14:47 »
Start looking for a ISV jack plug socket first trace it back.
Its proberly been bypassed check for plated work on the head where the inlet should stick out?
Why did you want a new ISV? Becuase if your has been diverted its not the ISV for sure LOL!
Offline Danr
« Reply #6 on: 20 May 2007, 15:11 »
I didnt know it had been bypassed at the time  :tongue:
Right been for another look and i have the black pipe from the air pipe, which goes to the isv in the pic but it the runs under the dizzy into what i believed was the isv, there is a plug into the back of this but it doesnt fit the isv i have been sent, cant find anythin round the front of the block which looks similar?
« Reply #7 on: 21 May 2007, 11:35 »
Looks to me like someone has bodged on an 8v k-jet unit, you'll need to find a 16v k-jet motor and pinch the isv pipes off it, as well as the plug & a length of loom as it looks liek theyve chopped off the ISV plug and soldered on the 8v plug!
Either that or thats what really early 16vs got?
Offline Danr
« Reply #8 on: 21 May 2007, 16:58 »
Well acording to dubsport early 16vs had a different isv set up, so i need to find something different to what i have got.
Offline Philpy
« Reply #9 on: 26 May 2007, 09:15 »
My valvers on an E reg and looks the same as Rowlers.... Not sure whats going on with yours  :sad:
