Author Topic: Redex.  (Read 3641 times)
Offline blinky88
Redex.
« on: 15 May 2007, 23:27 »
" Redex Petrol Treatment
-Helps increase fuel economy
-Cleans carburettors
-Helps restore performance
-Reduces emissions "
Anyone had any experience with this?
Does it work?
I have heard mixed reviews, spanning from increasing bhp and mpg to causing masses of white smoke from the exhaust!
Help shed light on the situation!
Offline Mr Blue
Re: Redex.
« Reply #1 on: 15 May 2007, 23:30 »
Tried it
Crap. Didnt do anything
Offline dabill
Re: Redex.
« Reply #2 on: 15 May 2007, 23:57 »
i've never tried it, but nearly did, and everyone i know (including a bloke working for local volks dealer) said not to waste my time, and bang a full tank of bp ultimate or shell in... then go for a spin...
noble tuned - and still not fast enough!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Redex.
« Reply #3 on: 16 May 2007, 00:05 »
tbh, i have noticed a diff, i think.. extra mpg at least, and slightly cleaner running
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline cняis
Re: Redex.
« Reply #4 on: 16 May 2007, 00:24 »
if your head is all coked up (on the car  :wink:) then i suspect it will make a difference combined with a thrashing up to the limiter (when the car is warm)
what worked well for me is the old "water through the vacuum pipe when engine is hot" trick, that decoked the bugger and stopped my terrible pinking - plus it cost nothing!! :cool:
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: Redex.
« Reply #5 on: 16 May 2007, 06:39 »
I tried it recently...noticed better mpg+slightly better idle, you get 2 treatments in each bottle, havnt done the second one yet as someone advised a 500mile interval between treatments.
Offline adyh
Re: Redex.
« Reply #6 on: 16 May 2007, 09:50 »
Ive used it before and it seemed to work, the smoke out the back is all the crap being burnt off .
Offline Len
Re: Redex.
« Reply #7 on: 16 May 2007, 09:57 »
have used it regularly in all my own cars. Not all claims can be justified but it helps.
www.sas.org.uk
www.the-ace.org.uk
Offline bored_Welsh_lad
Re: Redex.
« Reply #8 on: 16 May 2007, 10:24 »
if you want to decoke then powerboost is pretty good.. We had a RR session in our local club and tried this stuff... loads of sh!te out the back pipe but gained 6 brake in an astra redtop. I know its not huge amounts but then we tried a standard airbox v cone v filter and swiss cheese airbox and the filter and swiss cheese came out on top.
So not always good advice to change to a cone filter when a modded airbox and decent performance filter can give better gains
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline joey
Re: Redex.
« Reply #9 on: 16 May 2007, 21:11 »
just recently swapped over to super unleaded, after years of supermarket fuel and redex.
i can tell you that the car is running much smoother, less engine noise and no pinking.
 :smiley: i,m so happy. :smiley:  hope it lasts!
