Author Topic: electric window help please  (Read 1065 times)
Offline crazy steve
« on: 15 May 2007, 23:03 »
my rear window is broke i took the  door card of and theres bits of white plastic in there i can get it to stay closed but if i undo it it slide right down what do i need to get to fix it and is it a hard job cheers
its a p plate gti 16v 5 door
 :angry:
Offline GuvGTI
Re: electric window help please
« Reply #1 on: 16 May 2007, 01:27 »
the window can be three things
1) loose connection of wire, sometimes brown wire
2) window motor
if you can hear something moving when pressing the switch ie like a whining, then the motor is working
3) window regulator.
I rekon the regulator has gone.
Offline billy_vw
« Reply #2 on: 16 May 2007, 03:08 »
regulators are a common fault
MK5 GT TDi
Offline firstgolfgti
« Reply #3 on: 16 May 2007, 07:24 »
I have had the some problem on both my rear door electric windows. The local dealer said its the motor, but upon further investigation and some advice from an independant dealer it turned out to the metal regulator that slides up and clamps the window in place.
A lot of vw breakers said I had to buy the whole bit including motor, what I found was that you can get a regulator off a manual windowed golf that it's exactly the same part. Ok I had to buy a manual window mechanisim(which will go in the bin) for £7 :smiley:, but cheaper than trying to but an electric one.
You need some small pliers to get it off and maybe a small flat terminal driver to leaver the old one off, make sure when you remove the old one that electric window is about half way down this makes life much easier especaily when fitting a new one.
This seems to be a common problem, make sure you do this on a dry day or have a garage.
I had thought of getting a batch of new ones made up and selling them on ebay how hard can it be???????
Good Luck
Offline adyh
« Reply #4 on: 16 May 2007, 16:37 »
I had a similar problem , all i did was take the mechanism out of the car , and repair the broken plastic bit by cable tying the metal part in place .
Offline crazy steve
« Reply #5 on: 16 May 2007, 17:56 »
thats for all the help people i will give it a go when the weather gets better ...cheers  steve
